Heater Not Working
  • Neil
23 Sep 2011 14:05 #22396 by Neil
Heater Not Working was created by Neil
Hi all, I'm new here and I've just bought an 04 Jimny soft top.
The heater does not give any heat at all, the engine temp is normal, I noticed the top hose from the radiator is hot and the bottom hose is cold. can anybody help me with this problem.
Thanks
23 Sep 2011 15:34 #22398 by facade
Replied by facade on topic Re: Heater Not Working
Most likely someone has given the plastic levers on the side of the heater a kick and dislodged them.
Have a look from the drivers side at the white plastic levers on the side of the heater. Get someone to move the temperature control and make sure they move.
If everything looks all right, you need to make sure the rubber pipes at the back of the engine are getting hot: these lead to the heater.
The radiator hoses at the front are supposed to be hot at the top and cooler at the bottom.
  • dirtydogz
23 Sep 2011 15:42 #22400 by dirtydogz
Replied by dirtydogz on topic Re: Heater Not Working
This might help
Attachment heater.jpg not found
  • Neil
23 Sep 2011 16:50 #22408 by Neil
Replied by Neil on topic Re: Heater Not Working
Thanks very much guys I'll check that out tomorrow.
Cheers.
  • myers647
23 Sep 2011 20:17 #22417 by myers647
Replied by myers647 on topic Re: Heater Not Working
hi mate mine worked when i 1st got the jimny but then in the middle of last winter it packed in i think its the heater matrix , I'v checked all the hoses and heater controls and they all function as they should. I havnt done anything the heater heater matrix is about £60. I'v got an inverter in the car so im just going to plug a normal fan heater into it that is much cheaper. I hope this works or im going to freeze my B*lls off this winter because its forecast another bad one Bring on the Jimny.
James
  • Az1987
24 Sep 2011 14:08 #22430 by Az1987
Replied by Az1987 on topic Re: Heater Not Working
My heater matrix started leaking last weekend replaced in a rush today not to hard took about 4 hours to do and got 2nd hand one for £30.
Time to create page: 0.211 seconds
