Brake Balance Correction Bracket
- doncarlyon
21 Sep 2011 08:14 #22242
by doncarlyon
Brake Balance Correction Bracket was created by doncarlyon
Who has fitted one of these? Are they really needed?
Car will need MOT'd in November so just looking at things that "may" need sorting before hand.
Other car will be SORN'd at the end of Sept so Jimny will be used every day.
- srcars
21 Sep 2011 14:36 #22274
by srcars
Replied by srcars on topic Re: Brake Balance Correction Bracket
21 Sep 2011 14:41 #22276
by Obarno
Replied by Obarno on topic Re: Brake Balance Correction Bracket
I fitted something similar to mine after its MOT as the back brakes gave a rather low reading on the brake test machine. The tester didn't know why it was low as the handbrake reading was good. I realised, added the bracket extension, and the following year for its MOT the reading was normal so I guess the brake balancer does have some effect!
- doncarlyon
22 Sep 2011 13:54 #22345
by doncarlyon
Replied by doncarlyon on topic Re: Brake Balance Correction Bracket
Thought I would have a look under mine to see if it already had the bracket and it hasnt...
It also only has half of the spring, looks like its fell apart!
Can you buy the spring on its own?
Time to create page: 0.158 seconds
