Yes me again - Tyres :-)
- darthloachie
you will need to do a 4.5" spring lift and a 2" body lift to fit the Mudzillas and then trim back the wheel arches
you should get away without the body lift if you're fitting the 31"s
Former owner of Little "Ooky", who has now started a new life in Shetland
- TomDK
darthloachie wrote: think you'll need modulars with more offset than the standard wheels and I would go for wider wheels 7.5" if fitting 31x10.5x15 or 10" if fitting the Mudzillas
Do they have to be modulars?
I've seen a 4,5" spring lift kit somewhere on the internet, but now I can't remember where. Perhaps you can enlighten me?
Okay, www.dgtuning.com have them, but it should be possible to find it cheaper, right :-)
- Nobby22
Off road armoury do one. Not cheap but there stuff looks top quality. And they are based in the uk.
Nobby
- TomDK
Nobby22 wrote: www.ora-store.com/#!menu
Nobby
Okay, thanks. I'm almost sure I saw a cheaper kit somewhere. Well, just have to keep searching
Or else, I think I'll just go with a cheaper 3" spring lift and then perhaps also 2" body lift if needed
- darthloachie
No - they're just cheap for new wheels - you could also use vitara fatboy alloys - they are 10" wide and cheap off ebay
