front fog lights
- myers647
14 Sep 2011 18:27 #21901
by myers647
front fog lights was created by myers647
Hi everyone,
I have front fog lights fitted in the front bumper and they are wired up to a relay and do work but , there is no switch/button inside the to turn them on. does anyone know if the wires are hidden any were behind a blanked off button/switch.
Thanks
james
Thanks
james
14 Sep 2011 22:02 #21918
by kirkynut
Replied by kirkynut on topic Re: front fog lights
Do you not have a switch on the dash for them next to the rear foglight switch???
If you do the relay is on the bulkhead under the bonnet near the battery on the drivers side and I think mine is black and green.
I use mine to switch on my cage roof lights now. Mine came with them from the factory it seems so this is part of the car's loom.
Otherwise start from scratch with your own relay that has a feed to the switching side of the relay from the headlights but broken by a switch you install to the dash. I think the headlights have a permanent live and are switched by the negative side so you'll have to put the switch on the negative side with the feed via the negative side to your relay and a permanant live to it.
Hope this helps and is clear... I'm 3 Old Speckled Hens under as I type this so it might be as clear as mud!!!
- mark1971
15 Sep 2011 09:37 #21932
by mark1971
Replied by mark1971 on topic Re: front fog lights
Mmmm old speckled hen, that old mind scrambling ale..... Love it!
- myers647
15 Sep 2011 15:29 #21942
by myers647
Replied by myers647 on topic Re: front fog lights
Hi thanks for the reply,
the fogs in the bumper are factory fitted, its got the wiring loom already fitted with the relay etc, but there is no switch on the dash only one for the rear fogs. I just didt know if anyone else's jimny had this.???
Thanks
James
Thanks
James
Time to create page: 0.261 seconds
