got the wobbles
  • Cider
11 Sep 2011 18:21 - 11 Sep 2011 18:23 #21678 by Cider
got the wobbles was created by Cider
Hi all
Well been busy this weekend and fitted a +3inch springs"old pro comp springs sagging" and panards all went well could drive 70mph with no wobble. "standard 205`s"
today had a go at fitting 2 inch body lift ,all went well no issues.so swopped the muds form me old vit
30" Now can`t drive over 40 mph due to serve wobble.
My first stop will be getting front wheels balanced,but after that any Ideas please.
Cheers
Pete
Last edit: 11 Sep 2011 18:23 by Cider. Reason: amended post
  • vitara_mad
11 Sep 2011 18:50 #21685 by vitara_mad
Replied by vitara_mad on topic Re: got the wobbles
if it was fine before swapping the wheels over then it will just be the ballancing
i found the wheel ballancing to be the main problem on mine after i spent loads on changing everthing else
  • Az1987
12 Sep 2011 20:02 #21746 by Az1987
Replied by Az1987 on topic Re: got the wobbles
As above poss just wheels need balancing but don't just get the fronts done go down to a proper tyre fitting place and ask them to balance all 4 and put the best 2 to the front, as the less grams it needs to balance the more stable the wheel is a speed.
  • Cider
14 Sep 2011 10:05 - 14 Sep 2011 17:36 #21856 by Cider
Replied by Cider on topic Re: got the wobbles
Hi
Many thanks for your replys so I took it to ATS got all four wheels balanced and got them to fit the best up front.
Now I`ve can go 60mph without any wobble"didn`t take it beyond that"
Well Happy Thank You
Cheers
Pete
Just checked the rear wheel only to find 24 different lead balance weights on it
Last edit: 14 Sep 2011 17:36 by Cider.
Time to create page: 0.172 seconds
