brake line
  • jason92
11 Sep 2011 08:17 #21630 by jason92
brake line was created by jason92
y does the extended kit come with 3 brake lines how do u fit them ??
  • doncarlyon
11 Sep 2011 08:38 #21631 by doncarlyon
Replied by doncarlyon on topic Re: brake line
2 at the front, 1 at the rear!
I think they are a banjo bolt type fitting, you will need to bleed the brakes after fitting.
  • jason92
11 Sep 2011 09:48 #21636 by jason92
Replied by jason92 on topic Re: brake line
thanks i no how to fit the lines etc but dn where thr one at the rear is ment to go i could easily do it if i knew where the rear one went thanks for the help
  • doncarlyon
11 Sep 2011 10:06 #21639 by doncarlyon
on the drivers side at the rear, you will see the standard one if you have a look :)
  • dirtydogz
11 Sep 2011 10:15 - 11 Sep 2011 10:18 #21640 by dirtydogz
Replied by dirtydogz on topic Re: brake line
Attachment DSCF1547.JPG not found
Attachment DSCF1552.JPG not found
Hope this helps ;)
Last edit: 11 Sep 2011 10:18 by dirtydogz.
  • jason92
11 Sep 2011 20:43 #21692 by jason92
thanks i will do it one day this week when im fitting my 2" lift kit and 235 75 15 tyres and put up lots of pics to help others if i can work out how to upload pics
