WINCH
- myers647
08 Sep 2011 19:15 #21530
by myers647
WINCH was created by myers647
Hi everyone,
I'm sure this has been asked before but what size winch should i get. My jimny is my daily ride so nothing too heavy just something that will get me out if i ever manage to get it stuck when off roading,
which is not too often to be honest. There are a few on Ebay at the minute but a bit unsure.
Thanks
James
Thanks
James
- X-Eng Simon
08 Sep 2011 19:58 #21531
by X-Eng Simon
Replied by X-Eng Simon on topic Re: WINCH
Buy at least a 9000lb winch. Although a Jimny is quite light and you might think you don't need as big a winch as a Land Rover for example, you can push just as much mud in front of you as a Land Rover - and that tends to be when you need the power!
I would avoid the real cheap winches on eBay - they are cheap for a reason! The best value at the moment are the Tds / Goldfish winches from either Goodwinch or Winch Solutions. They will last for ever, are waterproof and have a decent resale value if required. They are actually a superb bit of engineering and it's no surprise that most challenge trucks use them on the back.
I have one on my 110 and another two which are destined for the mid & rear winches on the Jimny. I have yet another one which I've built a multi-motor conversion for which performs as well as an 8274. That may well go on the front depending how the mood takes me!
Si
Si
- mcjimny
08 Sep 2011 21:08 #21533
by mcjimny
Replied by mcjimny on topic Re: WINCH
Most of the guys i know that challenge use goldfish winches.
If its your daily drive why not make it removable. Just remove it for daily duties and slot it back in for playing.
You know jimny's don't get stuck though - especially black ones
I like to just make out i'm stuck so my mate has an exuse to play with his winch.............honest.
- vitara_mad
11 Sep 2011 16:32 #21655
by vitara_mad
Replied by vitara_mad on topic Re: WINCH
this would be just right for a jimny :woohoo:
www.bigjimny.com/index.php?option=com_ku...1&id=20925&Itemid=75
- unsure
11 Sep 2011 17:04 #21662
by unsure
Replied by unsure on topic Re: WINCH
I run a TDS in the rear and it is very good, a mate runs it on front of hi Hilux axled SJ and they work a treat and prices aren't half bad either
Time to create page: 0.158 seconds
