Clutch Return Spring???
04 Sep 2011 07:08 #21276
by SpeeLaT
Clutch Return Spring??? was created by SpeeLaT
Replaced the clutch yesterday and noticed that the Workshop Manual says that it has a return spring on the release bearing arm. Not on mine, in fact it has a different arm to that shown in the manual, there is no hole to hook a spring through and the spring mount is missing from the bell housing. (It is the same bearing fork as in Martins Clutch Replacement guide)
So how does the fork move the bearing back away from the pressure plate?
Mine just sits there, if this is how its set up then it would be why the previous clutch was fine but the bearing was totalled This is with the clutch set up with about an inch of free play.
- dirtydogz
04 Sep 2011 08:55 - 04 Sep 2011 08:58 #21278
by dirtydogz
Replied by dirtydogz on topic Re: Clutch Return Spring???
lf its a sohc its spring loaded were you clip it on to the gearbox it don't have a return spring its only fitted on the dohc like martins.
hope this helps.
DIRTYDOGZ
hope this helps.
DIRTYDOGZ
Last edit: 04 Sep 2011 08:58 by dirtydogz.
04 Sep 2011 09:24 #21281
by SpeeLaT
Replied by SpeeLaT on topic Re: Clutch Return Spring???
That's it then it is a SOHC.
Thanks.
Thanks.
- dirtydogz
04 Sep 2011 10:01 - 04 Sep 2011 10:02 #21287
by dirtydogz
That's OK we are here to help g
d luck.
DIRTYDOGZ
DIRTYDOGZ
Last edit: 04 Sep 2011 10:02 by dirtydogz.
Time to create page: 0.208 seconds
