Clutch biting point
- hulatt
08 Sep 2011 10:44 #21513
by hulatt
Replied by hulatt on topic Re: Clutch biting point
I managed to find it purely by touch, it was probably an M6 bolt with a lock nut on that had come loose. I tightened it back up to the lock nut, then tested there was about 10mm of free play. The bolt was right at the top of the lever, reaching up from the back of the pedal I could feel the bottom of it if that helps?
I can try taking a photo if u like when I get home on saturday if your still stuck?
08 Sep 2011 15:22 #21523
by Halford
Replied by Halford on topic Re: Clutch biting point
Thanks Simon
just been out and snapped a load of photo's in the hope I'd see what was going on.
I'm assuming that's it
will have a go in the morning
:blink:
:blink:
- adamatdraycott
09 Sep 2011 04:39 #21535
by adamatdraycott
Replied by adamatdraycott on topic Re: Clutch biting point
Unless the nut is loose, the pedal travel has been the same since it came out of the factory.
No matter how loose the cable, the pedal will still move in the same way.
