SJ transfer box and prop spacer
- Cider
24 Aug 2011 19:44 #20847
by Cider
SJ transfer box and prop spacer was created by Cider
Hi All
Just fitted a rocklobster tonight"thank you Rockwatt for the transfer mounting bucket/cradle its a piece of art"
Now the problem i have is the sj prop shaft "between the gear box/transfer box seems to short and looks dangerously close to the end of the gear box output shaft.
Would a prop spacer sort this problem out prop from a sj 410
Cheers
Pete
Cheers
Pete
25 Aug 2011 07:30 #20858
by Obarno
Replied by Obarno on topic Re: SJ transfer box and prop spacer
Yes!
The 410 prop is about an inch shorter than the 413 prop. The best thing is to push the prop into the gearbox, pull out about 10mm to allow for movement and measure the gap to the transfer box flange. Then get a spacer that size - probably an inch, but maybe 1 1/2 inches.
Or get a 413 prop!
Or get a 413 prop!
- Cider
25 Aug 2011 09:47 #20862
by Cider
Replied by Cider on topic Re: SJ transfer box and prop spacer
Hi
Thank you for the answer " didn`t know that there`s a difference in sizes between 410 and 413
So ordered a prop spacer while I sorce a 413 prop shaft
Cheers
Pete
Cheers
Pete
Time to create page: 0.160 seconds
