Wheel Nuts - Aluminium Wheels vs Steel Different?
- teafortwo0789
17 Aug 2011 15:37 #20558
by teafortwo0789
Wheel Nuts - Aluminium Wheels vs Steel Different? was created by teafortwo0789
Are the wheel nuts on Aluminium Wheels different that Steel wheels?
I want to change from Ali wheels to steel. In the parts book they have different numbers, are they really different?
I'm sure you off roaders will know.
Thank you.
Thank you.
- Keefe
17 Aug 2011 15:56 #20560
by Keefe
Replied by Keefe on topic Re: Wheel Nuts - Aluminium Wheels vs Steel Different?
Just check but if I remember correctly.......
Alloys to steel = ok
Steel to alloys = new nuts/bolts.
I swapped my steel wheels on a Suzuki Carry van for alloys and used the old nuts.
I lost a wheel whilst turning into work and on checkin, the other three had come loose.
The alloy wheel nuts have a larger shoulder. I think(?) the taper is the same though.
K
K
- teafortwo0789
17 Aug 2011 18:07 #20580
by teafortwo0789
Replied by teafortwo0789 on topic Re: Wheel Nuts - Aluminium Wheels vs Steel Different?
Thank you. I'll take a good look at the taper fit and length.
- Keefe
17 Aug 2011 19:15 #20585
by Keefe
Lots of info on here.
www.performancealloys.com/wheel-nuts-wheel-bolts.aspx
In fact, this is where I got my wheel nuts from for the Carry and my Mazda.
Plenty of reading for you.
K
K
17 Aug 2011 20:27 - 17 Aug 2011 20:35 #20598
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Wheel Nuts - Aluminium Wheels vs Steel Different?
Wheel nuts £1.30 each from BITS4VITS
www.bits4vits.co.uk/store/vitara-/-x90/w...s-open/prod_132.html
2002 JLX Soft Top
Last edit: 17 Aug 2011 20:35 by dirtydogz.
The following user(s) said Thank You: teafortwo0789
18 Aug 2011 22:02 #20665
by kirkynut
Replied by kirkynut on topic Re: Wheel Nuts - Aluminium Wheels vs Steel Different?
It is my understanding that the taper is different and this is why they should be the right type for the wheels.
I think a 60 deg taper is for alloys but this is an impression I have gained over time from reading, not from intended research.
I do not know what the taper is on steels.
Time to create page: 0.386 seconds
