speedomiter
  • guitarman
16 Aug 2011 07:14 #20423 by guitarman
speedomiter was created by guitarman
My speedomiter or my mileage clock wont work, I look for fueses,could not find any for it has any1 got any information 2help.
16 Aug 2011 07:46 #20428 by mlines
Replied by mlines on topic Re: speedomiter
Have you checked you have not ripped the wire off of the transfer box underneath the car?
Sent from my HTC Desire using Tapatalk
The following user(s) said Thank You: guitarman
  • ZookFastback
16 Aug 2011 07:50 #20429 by ZookFastback
Replied by ZookFastback on topic Re: speedomiter
Yep, I have this problem on and off for about 8 years. The speedo stops working but the tacho keeps on going. I find that the fuse box under the BONNET is the culprit, with wires coming loose underneath them. A bit of a jiggle and spray with de-watering spray such as 5-56 usually fixes it.
In the meantime, if you have a Jimny with the G13BB engine, such as a Jimny soft-top from 2001 like mine, the tacho can be used in the following fashion.
5th Gear 2,000 revs = 60 kph, 3,000 revs = 80 kph, 4,000 revs = 100 kph
4th Gear 2,800 revs = 60 kph, 3,800 revs = 80 kph
These figures are slightly optimistic but that just means you will not be going quite as fast. :)
  • ooky_123
16 Aug 2011 08:06 #20433 by ooky_123
Replied by ooky_123 on topic Re: speedomiter
on our first Jimny, we had only had it 2 hours, and had covered less than 10 miles when we lost all speedo and rev counters. after almost 8 weekd of trial and error, suzuki realised the multi connector under the dash wasnt fully snapped together ... and was vibrating loose, but contact was intermittant
Time to create page: 0.188 seconds
