shock lengths
  • awebb
14 Aug 2011 14:59 #20344 by awebb
shock lengths was created by awebb
hi, first of all is there much difference between a 2" lift and a 3" lift? obviously an inch but off road wise does it make much of a difference?
my problem is at the moment i have a 2 inch lift and 2 of the shocks are gone, id like to get a 3 inch lift in the future but cant afford the full kit at the moment, so could i buy 3" shocks and use them with a 2" lift?
im not sure what shocks iv got on at the moment but the ride is pretty hard so to soften things up a bit would i be best with pro comp es1000 shocks?
any helps would be great, thanks alot
  • darthloachie
14 Aug 2011 15:18 #20345 by darthloachie
Replied by darthloachie on topic Re: shock lengths
buy +3" shocks and 1" spring spacers :)
  • awebb
14 Aug 2011 15:22 #20346 by awebb
Replied by awebb on topic Re: shock lengths
but would i not need panhard rods and radius arms?
  • supergaz
14 Aug 2011 19:17 #20357 by supergaz
Replied by supergaz on topic Re: shock lengths
with more than 2'' you will need them.
  • darthloachie
15 Aug 2011 08:07 #20370 by darthloachie
to save money you could fit castor correction bushes and panhard bar relocation brackets form jimnybits
whether it is worth the extra 1" lift depends on what sort of offroading you do - if its greenlaning the you don't need to but if its pay and play then it will help as it will lift the bottom of the diff higher which is useful if you in ruts made by heavy landrovers on 35"s
  • doncarlyon
15 Aug 2011 09:32 #20372 by doncarlyon
Replied by doncarlyon on topic Re: shock lengths
No eBay APP ID and/or Cert ID defined in Kunena configurationThese seem a good deal
Time to create page: 0.169 seconds
