Re: M13A valve clearances?
  • JonnyJimny
15 years 3 months ago #20110 by JonnyJimny
M13A valve clearances? was created by JonnyJimny
Hi all, My Jimny sounds a touch tappety when i fire it up from cold, and just wondered if the valvle clearance is adjustable, and if so, what are the specs?
Any help is aprecciated. Jon.
  • Adamski
15 years 3 months ago #20266 by Adamski
Replied by Adamski on topic Re: M13A valve clearances?
I can't help here however mine also sounds a bit tappety, I don't know whether that is the norm with the M13 engines. Hopefully someone can answer this thread :)
  • Keefe
15 years 3 months ago - 15 years 3 months ago #20276 by Keefe
Replied by Keefe on topic Re: M13A valve clearances?
Having to do it again 'cause it didn't post how I'd typed it. Stroll on.
M13A
Intake..........Cold.......0.18 - 0.22mm..........Hot.....0.21 - 0.27mm
Exhaust.......Cold.......0.28 - 0.32mm..........Hot.....0.30 - 0.36mm
They are shim & bucket, not the old type screw & locknut.
hth
Keith :)
Last edit: 15 years 3 months ago by Keefe.
5 years 3 weeks ago #239543 by Buzz
Replied by Buzz on topic Re: M13A valve clearances?
Just started to maintain my daughter's Gen3 M13A Jimmer this year instead of taking to the garage. This year was ok with just basic oil/filter service but next year will probably need to do a bit more.
I think the service schedule suggests every other year for valve clearance check. I can't see time makes a difference to valve wear so probably best do them on mileage? Does 18,000m intervals sound ok? (Even that seems quite a soon for a low revving, low tune engine to me. Are you finding they need adjusting when you check?)
Also - I've done valve checks on motorbikes but never on cars before. Any videos/guides/advice for the M13A engine? I have googled a bit but nothing much jumping out for that engine.
Thanks all.
5 years 3 weeks ago #239545 by Busta
Replied by Busta on topic Re: M13A valve clearances?
Can't say I've ever heard of anyone checking them on the M series engines. I have a manual for the G13BB engine that states every 18,000 miles or 24 months, but that has a completely different system. I'd be very surprised if the M series is that often.
5 years 3 weeks ago #239547 by Lambert
Replied by Lambert on topic Re: M13A valve clearances?
I was under the impression that the valves were a bucket shims design and not prone to excessive wear until very high miles?
