front brake help
  • Garry
24 Jan 2010 14:07 - 24 Jan 2010 14:08 #2010 by Garry
front brake help was created by Garry
ive got a new set of pads, the correct ones, but cant get the piston back far enough to get them to fit in, any ideas?
is it a push back piston or windback? do i need a specific tool to do it? g clamp was useless
i know nowt about the jimnys brake system,
also the brakes are soft as a soft thing, had new rear shoes fitted last month, no off-roading done with them yet, so new front pads and disc will give a good hard pedal again?
Last edit: 24 Jan 2010 14:08 by Garry.
24 Jan 2010 17:06 #2014 by mlines
Replied by mlines on topic Re:front brake help
I push the pistons back using a G-Clamp and its fine, it will push the pistons fully back into the calipers with ease.
If it will not go back so that it is entirely flush perhaps the piston is sticking.
If the brakes are soft I would always look at the adjustment of the rear shoes, they need to be adjusted to be very close in order to get any real feel in the brakes.
Softness can also be caused by a flexible brake pipe "ballooning" under pressure.
  • Garry
24 Jan 2010 17:32 #2019 by Garry
Replied by Garry on topic Re:front brake help
thanks martin, my friend is a mechanic, so the jimny is going in next sat for pads, discs rear shoes and the system is getting bled
Time to create page: 0.135 seconds
