Radiator Overflow Tank
  • Sprocket
08 Aug 2011 17:52 #20089 by Sprocket
Radiator Overflow Tank was created by Sprocket
Hi
I'm new to Jimny's having only bought mine 3 weeks ago. One thing I've noticed under the bonnet is a plastic tank, similar to a washer bottle, and to the right of the radiator, connected to the radiator by a black pipe. From the tank there is a second pipe, arrowed as out, that ends after about 50 mm. I can't see anything that it was ever likely to have been connected to.
Does anyone know if this is just an overflow/header tank for the radiator or is there something I should be worried about?
  • dirtydogz
08 Aug 2011 18:11 #20093 by dirtydogz
Replied by dirtydogz on topic Re: Radiator Overflow Tank
Its to stop the header tank pressurising when the hot water come out of the rad
  • p1ngu32
08 Aug 2011 18:35 #20094 by p1ngu32
Replied by p1ngu32 on topic Re: Radiator Overflow Tank
Thats the expansion bottle, the pipe you are seeing is the overflow for the bottle and is supposed to be connected to nothing so that it can spill over on to the ground if it needs to, unless you overfill it or there is a problem with the cooling system then it will likely never overflow out of that pipe.
  • Sprocket
09 Aug 2011 05:35 #20102 by Sprocket
Replied by Sprocket on topic Re: Radiator Overflow Tank
Excellent. That was my best guess for what it was but I wasn't quite certain.
Time to create page: 0.174 seconds
