Jimny door adjustment
- Kmacker
07 Aug 2011 04:32 #20007
by Kmacker
Jimny door adjustment was created by Kmacker
Hi newbie here. Got my jimny in Jan to use for work (windfarm), dog, hill walking etc. Great wee motor. Have even hopefully got rid of jimny wobble that's been there from day one
Anyway, my question is this. I get wind blowing thru rear top corner of drivers window. Annoying. Looks like seal doesn't locate as good as on passenger side and that if door was raised at handle end by 1-2mm would fix. Can you adjust door and has anyone had same issue?
Thanks in advance
Thanks in advance
- Thank you received: 115
07 Aug 2011 09:20 #20009
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Jimny door adjustment
there's some big phillips screws in door (the lock itself) and the on the door-catch on the body ... adjust these to suit your needs?
Hope that Helps?
Hope that Helps?
Jalapeño, IISY?
- Kmacker
07 Aug 2011 17:59 #20033
by Kmacker
Replied by Kmacker on topic Re: Jimny door adjustment
Cheers m8. Will give this a go tomorrow if it ever stops raining...
