Axle oil fill plug
  • Mala43B
05 Aug 2011 10:38 #19981 by Mala43B
Replied by Mala43B on topic Re: Axle oil fill plug
Sorted! Whoop whoop...!
I used the old trick of applying heat to it using a blow torch and it came out with ease in fact it surprised me how easy it came out. I would recommend anyone that has the same problem to use this approach.
I have not bothered to buy a new plug even though I have rounded it, instead I used some of that copper silicon gasket sold in the big jimny shop to re-seal it as the sealing ring fitted to the plug didn't like the heat.
I just used pipe grips to tighten it.
Thanks for the help guys.
  • renard38
06 Aug 2011 16:47 #19998 by renard38
Replied by renard38 on topic Re: Axle oil fill plug
i have down this, more easy too unscrew:
[img
[img
[img
A+ ;)
  • meanbgreen
07 Aug 2011 02:35 #20006 by meanbgreen
Replied by meanbgreen on topic Re: Axle oil fill plug
use a chizel and hammer to rotate it until it breaks loose. Yes though your front axle is unlocked components still rotates inside so it'd be bad to run it dry
08 Aug 2011 10:40 #20055 by Johnniehec
Replied by Johnniehec on topic Re: Axle oil fill plug
meanbgreen wrote: Yes though your front axle is unlocked components still rotates inside so it'd be bad to run it dry
do they or don't they? now there's a question!! This question goes all the way back to the series Landrover dark ages. Optional equipment manufacturers sold loads of free wheel hubs to series owners as an economy aid (though many owners seemed to think they improved off road ability!)
Sounds logical, disconnect the hub ends of the half shafts (gear box end of front prop already disconnected in transfer box because you've selected 2 WD) so halfshafts diff and prop aren't "driven" by the wheels so don't turn saving fuel and wear. But how much resistance is there in the unlocked hub mechanisim and the transfer box internals, would they really not turn? Answers on a post card if anyone knows the answer.
John.
  • X-Eng Simon
08 Aug 2011 12:26 #20058 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Axle oil fill plug
With most things that won't come undone, after heating, freezing and WD40 have failed, I find welding something else to it is the answer!
Do you know what thread it is? I may know someone who makes replacements for Land Rovers - which might fit. If not, it's only a small change to the CNC program to make it!
Si
  • darthloachie
08 Aug 2011 12:28 #20059 by darthloachie
Replied by darthloachie on topic Re: Axle oil fill plug
John.
Yep - they dont turn - been under ours while the mechanic rotated the wheel and nothing moved when unlocked
then again the right one doen't turn when it is supposed to be locked (ongoing saga!!) :(
Time to create page: 0.182 seconds
