Axle oil fill plug
  • Mala43B
03 Aug 2011 18:27 #19914 by Mala43B
Axle oil fill plug was created by Mala43B
Hi can anyone help?
I've tried to remove the front axle fill plug using a 3/8 square drive adapter and breaker bar but I have slightly rounded it.
I've recently changed the front axle oil seal due to it letting oil out the axle into the swivel and out the swivel seal. I don't think there is any oil in the diff now (none came out when I removed the axle oil seal), am I right in saying when in 2WD the front diff/axle does not rotate and therefor I can still drive it without oil in the front diff?
How do I remove the rounded plug?
  • doncarlyon
03 Aug 2011 18:58 #19917 by doncarlyon
Replied by doncarlyon on topic Re: Axle oil fill plug
My drain plug is also seized solid... luckily all of the oil came out of the swivel hub when the kingpins were knackered :)
Will have to get a nut welded on then take it out that way
  • mcjimny
03 Aug 2011 19:35 #19921 by mcjimny
Replied by mcjimny on topic Re: Axle oil fill plug
I think these are available from the main stealer.
To get that out though spray some wd40 on for a few days then try some mole grips or a chisel and try to knock it round if you don't have access to a welder. If you can get a mate to help then try a combination of a couple of approaches.
I've run my diff dry before without realising. You'll be ok in 2wd though as you said the front diff won't rotate.
03 Aug 2011 21:16 #19925 by facade
Replied by facade on topic Re: Axle oil fill plug
My rear filler was stuck, and the square hole just turned into a round hole when I tried to undo it :ohmy:
However, it came undone very easily with a couple of little taps on a chisel knocking the edge anticlockwise.
Then I sinply filed a piece of hexagon until it fitted the hole in the plug and welded it in place. Comes undone with a spanner now. ;)
Seems the case with all the fasteners on the jimny, they are not particularly tight, just the heads are made of plasticene :huh:
  • ZookFastback
04 Aug 2011 06:49 #19929 by ZookFastback
Replied by ZookFastback on topic Re: Axle oil fill plug
You can run the car so diff is warm, then spray "Freeze all" onto the oil filler. This will cause the filler to shrink off and can then be easily removed. Gotta love modern technology.
:D
  • chechan rebel
04 Aug 2011 06:56 - 06 Aug 2011 10:15 #19930 by chechan rebel
Replied by chechan rebel on topic Re: Axle oil fill plug
Hmmm..............................i changed my front an rear diff oils other day, but all 4 of my plugs came straight out. Also did transfer today 2 came out................gearbox to go, ran out of oil. Got more oil, changed gearbox oil...............2 of them plugs came straight out to.
Edit: 6/8/2011
Last edit: 06 Aug 2011 10:15 by chechan rebel.
