Larger M16A or M18A throttle body?
- Sandez
02 Aug 2011 11:13 #19832
by Sandez
Larger M16A or M18A throttle body? was created by Sandez
I've got the feeling that my Idle Air Control valve is giving me all my idling issues, and once I get the special tool to remove it; the TS Star Torx bit; I'll remove it and clean it and give that a go.
Should that fail to work I'll be looking at replacing the throttle body, including all sensors. Since the IAC valve seems to only be available from Suzuki, given what their usual pricing would be like, I'm thinking the money could be better spent on upgrading the thottle body to increase air flow (and power :evil: ). Pricing for a second hand M13A throttle body was $150 with all sensors. I'm only assuming here but that would be cheaper than just the IAC valve from Suzuki, hence why I am considering this mod.
Firstly, what I was wondering, as this is my first part of my research into it, are the M16A or even the M18A throttle body the same size as the M13A? If not has anyone had any experience or knowledge of whether they would be a straight fit? Would I need to replace the intake manifold as well?
Any help/advice is appreciated.
Regards,
David
Regards,
David
- zaine
03 Aug 2011 10:26 #19883
by zaine
Replied by zaine on topic Re: Larger M16A or M18A throttle body?
ooo would also like to know if the larger tb's can be easily fitted :evil:
- Zapnologica
- Junior Member
06 Jun 2020 00:45 #223296
by Zapnologica
2015 Suzuki Jimny
4" 100mm Lift
M18A Motor
Crawler Gears
Dual Air Lockers
Lots of mods.
Replied by Zapnologica on topic Larger M16A or M18A throttle body?
Did anyone ever check this?
I know that the m13a throttle body is interchangeable with the m18a one on the m18a intake manifold.
So I suspect this would be possible.
The m18a TB is substantially larger..
2015 Suzuki Jimny
4" 100mm Lift
M18A Motor
Crawler Gears
Dual Air Lockers
Lots of mods.
06 Jun 2020 06:43 #223298
Replied by Riccy on topic Larger M16A or M18A throttle body?
M16 is as big as you will find easily in the UK.
The throttle body from a liana M16 fits and works on the swift M16 when in a Jimny, if thats any help.
With the Jimny the biggest restriction is the manifold itself. Its ported for the 1.3 (much smaller than the head apertures).
This pic shows the Jimny inlet manifold vs the actual port size:
You can go down the ITB route :whistle: Thats what I'm running my M18 with now and its made a huge difference:
- sealine150
25 Jun 2020 22:20 #224002
by sealine150
Replied by sealine150 on topic Larger M16A or M18A throttle body?
So could i ask for something close to this thread.
I swap a M16 from swift to my 2009 Jimny.
What intake will make jimny works better?
26 Jun 2020 16:12 #224031
The swift one wont fit without some cutting & welding. Swift one also has a drive-by-wire throttle body, which is no good for a Jimny.
Best thing is to fit the M16 with the jimny manifold to start with and see what its like. There are only tiny gains to be had from the various options without going to throttle bodies or similar setup (big expense).
sealine150 wrote: So could i ask for something close to this thread.
Time to create page: 0.168 seconds
