no drive from front axle
- darthloachie
01 Aug 2011 13:05 - 01 Aug 2011 13:09 #19794
by darthloachie
Replied by darthloachie on topic Re: no drive from front axle
need to ask a thicko question
I need to count the teeth on the diff to get the correct replacement
the crown wheel is obviously the large one but which is the pinion? and is it any different with an ARB fitted?
thanks in advance
Attachment arb.jpg not found
thanks in advance
Last edit: 01 Aug 2011 13:09 by darthloachie.
01 Aug 2011 14:19 - 01 Aug 2011 14:22 #19796
by facade
Replied by facade on topic Re: no drive from front axle
The pinion is the little gear that meshes with the crownwheel.
To find the diff ratio: divide the teeth on the crownwheel by the teeth on the pinion.
However, as far as I understand it, the ARB is the spool part containing whatever is broken. You fit your crownwheel to the spool, and refit.
A new differential is not going to help you I'm afraid, the ARB unit wants to come apart to find what is broken, devon4x4 carry ARB spares and may be able to help.
Attachment airLockerAnimation.gif not found
Last edit: 01 Aug 2011 14:22 by facade.
- darthloachie
01 Aug 2011 17:44 #19805
by darthloachie
thanks
its going off to staffordshire4x4 for them to sort for me
- darthloachie
07 Aug 2011 16:52 #20031
by darthloachie
mmm........
diff and ARB checked out and it all works OK
thoughts are back to a faulty manual locking hub
- chechan rebel
08 Aug 2011 04:12 #20044
by chechan rebel
Replied by chechan rebel on topic Re: no drive from front axle
Sounds like one them pain in ass things to find...................good luck with it though.
- darthloachie
12 Aug 2011 13:30 #20251
by darthloachie
Its all back together now - turned out to be the free wheeling hub not locking properly
- it got a good clean out and regreased and with all the wheels in the air on a ramp all the wheels drove in 4h
ready for the Bigjimny event now - trailer's booked, wife's cherokee stolen for the tow car
Time to create page: 0.479 seconds
