Advice needed, when to change out the kingpin
- Cocopolo
25 Jul 2011 09:50 - 25 Jul 2011 09:51 #19478
by Cocopolo
Replied by Cocopolo on topic Re: Advice needed, when to change out the kingpin
I personally changed the kingpin bearings twice and one cv joint in the first year of life of my jimny ... then i learned a trick which avoid water and mud to enter the kingpin housing and the joints: fullfill the hubs with grease ...
I made some pictures of this easy operation:
1) unscrew one bolt from lower kingpin plate
img837.imageshack.us/i/dscn3638m.jpg/
2) unscrew one of top kingpin plate
img219.imageshack.us/i/dscn3640o.jpg/
3) unscrew greaser nozzle
img232.imageshack.us/i/dscn3641z.jpg/
4) push greaser head into the free lower hole
img854.imageshack.us/i/dscn3642.jpg/
5) pump grease inside untill it exit from upper hole
img233.imageshack.us/i/dscn3643r.jpg/
Doing this procedure frequently since last 3-4 years, i had no more kingpin or cv joint failures ...
Hope this can be usefull
Last edit: 25 Jul 2011 09:51 by Cocopolo.
- supergaz
25 Jul 2011 15:51 #19487
by supergaz
Replied by supergaz on topic Re: Advice needed, when to change out the kingpin
Sounds a good idea, would this not overload the CV with grease? I never know how much grease is to much or to little. Would this then make the swivel seal start leaking under pressure? Sorry i'm still new to the jimny thing and haven't had to change kingpin bearings yet!
- mcjimny
25 Jul 2011 16:07 #19490
by mcjimny
Replied by mcjimny on topic Re: Advice needed, when to change out the kingpin
There is a recomended amount to pack the cv's with but i can't remember what it is! Everytime i've done the job i've gone to town on the cv's with grease and they still click off road!
I'll try the motorcross grease next time though.
As for how hard a job it is, it's easy enough if you are confident with simple mechanics ie oil change, brake pads etc. The how to guide on here is very usefull. It is the smelliest and messiest job on a jimny though.
- supergaz
25 Jul 2011 16:17 #19491
by supergaz
The smelliest messiest job is mine! I'm a Garage Equipment / Commercial Vehicle brake tester engineer! It pays for the Jimny!
I'm tempted on a tub of Marine grease as Martin has in the Bigjimny shop.
Suzuki recommend 100ml of grease in the CV.
25 Jul 2011 16:21 #19492
by Foxtrot
Replied by Foxtrot on topic Re: Advice needed, when to change out the kingpin
Thanks for the help, the kingpins seem to be the Jimny's weakness and a regular money maker for the garages
- mcjimny
25 Jul 2011 17:04 #19499
by mcjimny
Since owning mine(nearly 3 years) i've done:
1 cv, kingpin bearings twice, swivel hub seals once, both rear wheel bearings, rear wheel cylinder twice all on top of normal service stuff pads, oil etc..
Imagine how much that would have cost me if i hadn't done the work myself. The only thing i've paid to have done was the clutch at £270
