Advice needed, when to change out the kingpin
24 Jul 2011 17:28 #19446 by Foxtrot
Hi Guys, some assistance from experience Jimny owners required. My drivers side kingpin has started to weep oil (see photo), at what stage should I change it out and will one of Martins kingpin kits cure it, thanks
Attachment weepingkingpin.JPG not found
  • mcjimny
24 Jul 2011 18:40 #19454 by mcjimny
Personally mine looks like that when its had a hard time off road. I clean it up and it doesn't "weep" any more on road. If you jack it up there will be movement along the vertical plane when rocked with your hand top and bottom of the wheel iirc.
When my bearings are shot there's a noticable run of oil from the swivels and the diff oil usually sprays around the arch and over the inside of the wheel.
24 Jul 2011 18:49 #19457 by Foxtrot
Thanks mcjimny, I have noticed mine has sprayed oil around the tyre :( . They don't last long they were only changed out 12 months ago.
  • vitara_mad
24 Jul 2011 21:05 #19460 by vitara_mad
Replied by vitara_mad on topic Re: Advice needed, when to change out the kingpin
mine lasted 6 months but i suppose that comes down to how & where you drive the jimny
its not expensive to change them so best to change them as soon as you have to
  • mcjimny
25 Jul 2011 07:30 #19469 by mcjimny
I've done mine twice in almost 3 years of ownership so no they don't last long. Its not the cost of the job i dislike, its the job itself i hate, probably the messiest job on these things. I can do it in no time at all now too.
I'm interested to hear if the washer fix works for the next time i do mine. Hopefully coupled with the waterproof grease it should go some way to prolonging their life a bit.
25 Jul 2011 09:20 #19476 by Foxtrot
Thanks for the help, is it an easy job to do, I dont want to start taking it to bits then go to work in a taxi Monday morning :ohmy:
Time to create page: 1.119 seconds
