SJ transfer stick pictures
  • Cider
23 Jul 2011 14:04 #19394 by Cider
SJ transfer stick pictures was created by Cider
Hi
I`m looking for any pictures of their bent SJ transfer sticks when fitting the sj box into a jimny please
so it will give me a starting point before fitting my box
Cheers
pete
23 Jul 2011 14:55 #19397 by maverick
i have a SJ T-case in my Jimny ... i didnt bend the stick, i just made the hole bigger ... made the hole bigger at the rear/bottom of the hole (if that makes sense) ... so not the top end toward the front of the car, not the sides ...
Jalapeño, IISY?
  • vitara_mad
23 Jul 2011 15:38 #19399 by vitara_mad
Replied by vitara_mad on topic Re: SJ transfer stick pictures
i don't have a pic but if you start where the big bend is at the bottom make that straight & then test fit & adjust from there thats what i did & it worked out fine
  • Seawolfvarna
23 Jul 2011 18:52 #19408 by Seawolfvarna
Replied by Seawolfvarna on topic Re: SJ transfer stick pictures
You can check " how to" section and there you can find the answer of your question!
Time to create page: 0.192 seconds
