i need help: front prop spacer, with 3" radius arm
  • darthloachie
22 Jul 2011 17:21 #19359 by darthloachie
renard38 wrote: i have another problem: today i wanted to put on the shaft axle the 1" prop spacer. But there is not enough place. I think i need 0,5" prop spacer ( i have a transfert box 4.16 who come's from a samurai 413 )
have you got the same problem??????????
for 0.5 inch I wouldn't bother with a spacer, the splines on the prop will easily cope with that especially as you have castor correction arms
  • panosd
22 Jul 2011 17:27 - 22 Jul 2011 17:31 #19360 by panosd
When you will have the front axle drop the splines of the prop will come out to their limits.
After 8-9 times there will be problems and the prop splines will start to trim.
The arms look like the dg tuning one. www.dgtuning.com
Last edit: 22 Jul 2011 17:31 by panosd.
  • darthloachie
22 Jul 2011 17:32 #19361 by darthloachie
our jimny has a 5" lift and a standard length front prop for two years and a 3" lift since 2002 and the prop is still in one piece - its only had a replacement uj
  • renard38
22 Jul 2011 17:37 - 22 Jul 2011 17:38 #19362 by renard38
it's difficult for me to understand this ( i'm french ) So, 0,5" prop spacer, i must use this, yes or no????????
Thanks
Last edit: 22 Jul 2011 17:38 by renard38.
  • dadam
23 Jul 2011 05:07 #19371 by dadam
Thanks
Il dit que pour cette épaisseur il ne s'embêterait pas avec un spacer car le soufflet sur l'arbre compensera largement surtout avec des tirants corrigés Eric;)
  • renard38
23 Jul 2011 08:55 #19383 by renard38
merci bien ;)
Time to create page: 0.169 seconds
