i need help: front prop spacer, with 3" radius arm
23 Jul 2011 09:06 #19384 by Obarno
I disagree! With a 3" lift and castor correction arms a 1/2" spacer is probably necessary. The arms push the front axle forward slightly so that the springs are upright at normal ride height so already the prop shaft is extended. Then on full droop you will find the splines are very nearly at max length so to avoid damage and also out of balance movement its best to put the small spacer on. This is exactly the situation with my Jimny. Also the height at which the transfer box is mounted will have an effect on the prop shaft - if its mounted high, which some are, then another reason for using the spacer.
Voila!
  • darthloachie
23 Jul 2011 09:11 #19385 by darthloachie
sorry Renard
you do not need a spacer for 0,5"
  • renard38
23 Jul 2011 09:50 - 23 Jul 2011 09:51 #19386 by renard38
darthloachie wrote: sorry Renard
thanks, my friend dadam translated me your message ;)
in fact, the drive shaft gaiter, decreased by 1 cm so 1/2" will be ok. I'll put a 1/2" prop spacer because you can see the the beginning of the splines, and i don't want the water come's inside.
I'll take a picture when the rain stop :dry:
Before my the shaft axle measured 76,8 cm and now 78 cm so only 1/2" more long ( this is why i can't put the prop spacer 1" )
more pictures:
[img
[img
compare:
[img
[img
[img
[img
[img
before:
[img
now: ( more flex )
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
i'll have to lengthen the brake hose:
[img
A+
Last edit: 23 Jul 2011 09:51 by renard38.
  • renard38
23 Jul 2011 14:52 #19396 by renard38
the drive shaft gaiter, look, only 0,5" decreased:
[IMG
( in blue, the marine grease )
  • darthloachie
23 Jul 2011 19:35 - 23 Jul 2011 19:39 #19412 by darthloachie
looking good
Last edit: 23 Jul 2011 19:39 by darthloachie.
  • Cocopolo
25 Jul 2011 10:05 #19479 by Cocopolo
Well done Renard!
Very nice flex now!
Time to create page: 0.355 seconds
