Hand brake cable - into brake backing plate
- Thank you received: 115
17 Jul 2011 15:08 - 17 Jul 2011 15:09 #19069
by maverick
I've just replaced my rear wheel bearing, and to get the half shaft out you have to remove the hand brake cable from the brake backing plate ...
I always struggle in removing the cable through the hole as the cable has a 'pronged gizmo' that holds it in place ...
Has anyone got a tool (bought or own-made) to make the removal easy??
Jalapeño, IISY?
Hand brake cable - into brake backing plate was created by maverick
Attachment IMG_1630.jpg not found
Jalapeño, IISY?
Last edit: 17 Jul 2011 15:09 by maverick.
17 Jul 2011 15:18 #19070
Replied by mlines on topic Re: Hand brake cable - into brake backing plate
i tried a jubilee clip which worked but was probably more trouble than it was worth
17 Jul 2011 16:00 #19073
by facade
Replied by facade on topic Re: Hand brake cable - into brake backing plate
Just jab one prong inwards with a screwdriver, and bend the cable away from the prong to pull the tang through, jab another and bend again*, then jab the third and it pulls out.
*you can't let the first one back through when you do the second bend.
- Cider
17 Jul 2011 18:43 #19078
by Cider
Replied by Cider on topic Re: Hand brake cable - into brake backing plate
I had the same trouble
so I used a large cable tie pulled up FT seemed to work for me
Cheers
Pete
Cheers
Pete
18 Jul 2011 07:07 #19094
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Hand brake cable - into brake backing plate
Cheers guys ... i like the idea of the Cable Tie and also the jubilee clip, but this maybe a bit awkward to get in though ...
Jalapeño, IISY?
Time to create page: 0.411 seconds
