loud screeching noise continued
- george
17 Jul 2011 05:38 #19053
by george
this is for martin,not sure if you remember the noise coming from the front axle.well i have just got round to investigating the cv joints and on the way i came across a damaged kingpin bearing so it appears to be that cv joint is fine.procedure was carried out with ref to your how to section [very good] however i have made a mistake concerning the kingpin bolts.i have read it wrong and seperated the actual bolts themselves as not to get them mixed up.it appears this is incorrect should have marked the actual keepers top and bottom,why is it a problem if they are mixed,they look the same.will mixing them cause damage.
loud screeching noise continued was created by george
17 Jul 2011 06:58 #19054
by facade
Replied by facade on topic Re: loud screeching noise continued
I hope not :ohmy: I just cleaned them up and put them back any side/way up.
They all have the same part number in my epc
17 Jul 2011 07:43 #19055
Replied by mlines on topic Re: loud screeching noise continued
They are the same part top and bottom. Its just "good practice" when re-fitting used parts that they should go back in the same position/orientation as they will have developed a "wear pattern" from the previous use.
It will probably make little difference.
- george
17 Jul 2011 09:10 #19057
by george
Replied by george on topic Re: loud screeching noise continued
ok thanks for that,one other thing i need is a circlip for the half shaft none on ebay any ideas
