Laws and Fitting of CB Radio??
15 Jul 2011 12:00 #18988
by Obarno
Replied by Obarno on topic Re: Laws and Fitting of CB Radio??
Thanks Vaxxi for your thoughts - I will do a bit of experimenting. When I first put the antenna through the bonnet I ran a separate earth to it as I wondered how good an earth it would get through the bonnet. This produced more noise so I have taken it off.
With the Sammi I mounted the antenna on the spare wheel bracket,rather like Keefe, but it didn't make any difference - it still picked up interference from the pump, or somewhere. It was also difficult to get the swr correct when mounted there. The only thing that worked well on that car was a magmount, using the same antenna, fixed to the scuttle by the windscreen.
- Green
16 Jul 2011 14:33 #19038
by Green
Replied by Green on topic Re: Laws and Fitting of CB Radio??
Cheers for the advice, I shall do some looking around then! I Did try your ebay link but it says the item has been removed so dont know if you have another link for it?
Fortunately I have an adapter for my lighter socket that gives it 2 sockets and a USB point. I have an iPhone so just use the USB wire that it comes with and the USB point to charge it. Then one lighter socket for Sat Nav and the other for CB....if I ever come to use all 3 at once!!!
Andrew
Andrew
- mcjimny
16 Jul 2011 22:35 #19052
by mcjimny
Replied by mcjimny on topic Re: Laws and Fitting of CB Radio??
If you search for midland cb radio it should bring it up
i'll try the link again though
cgi.ebay.co.uk/MIDLAND-98-PLUS-80CH-UK-E...&hash=item45f863642c
17 Jul 2011 15:21 #19071
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Laws and Fitting of CB Radio??
TTI 80 channel cb +antenna kit £69.99.
www.maplin.co.uk/cb-radio-and-antenna-kit-509792
2002 JLX Soft Top
- ZookFastback
18 Jul 2011 07:05 #19093
by ZookFastback
Replied by ZookFastback on topic Re: Laws and Fitting of CB Radio??
- Green
18 Jul 2011 14:46 #19122
by Green
Ahhhh brilliant. Both of those models look ideal! Thanks very much for the replies, I have started putting by the pennys!!
Andrew
Andrew
Time to create page: 0.323 seconds
