Laws and Fitting of CB Radio??
  • Green
14 Jul 2011 12:46 #18943 by Green
Laws and Fitting of CB Radio?? was created by Green
Hello everyone,
Im thinking of getting a CB radio in my Jimny. I heard that you need a radio license to have one though. Can anyone clarify whether this is true or not??? I would do it without the license but Im a fairly young lad and cops will pull you for near enough anything these days....
Also, fitting a CB....I guess it just requirs a positive feed and a negative for supply then the circuit to the antenna, is that it??
P.S. Anyone going to the Berkshire 4x4 show?
Cheers,
Andrew
  • jason92
14 Jul 2011 12:55 #18944 by jason92
Replied by jason92 on topic Re: Laws and Fitting of CB Radio??
im only 19 my self dn if u need a licence never even thought of that ive got a cb i just put it in when i want to use it and ive just got it on a cigaret lighter... that show sounds like a plan where do u cum from close to the show im a couple of hours away (near horsham west sussex)
  • jason92
14 Jul 2011 13:01 #18946 by jason92
also were u planing the saterday or the sunday ??
  • mcjimny
14 Jul 2011 13:04 #18947 by mcjimny
Replied by mcjimny on topic Re: Laws and Fitting of CB Radio??
You don't need a licence for CB anymore it was done away with years ago.
Its simple to plumb one in, as you've already said just run a positive and negative from the battery and make sure theres an inline fuse on the positive. I used bullet connectors so i can easily remove it if i need to.
  • VAXXi
14 Jul 2011 13:09 #18948 by VAXXi
Replied by VAXXi on topic Re: Laws and Fitting of CB Radio??
If it's under 4 W of transmit power, you're safe. No license needed, CB = citizen's band.
Theory says it's better to connect the CB radio directly to the battery (cleaner power) and not the cigarette socket. I've connected it to the battery though, and I get lots of noise when the engine is on :angry: so experience on your own to see the results.
If you get a magnetic mount, you're good to go. If you're getting a fixed mount, it's more complicated.
  • jason92
14 Jul 2011 13:20 #18949 by jason92
a load of noise with enguine on = bad earth normally??
Time to create page: 0.196 seconds
