Overheating problems becoming expensive....
- jimny5
15 years 4 months ago #18838
by jimny5
Replied by jimny5 on topic Re: Overheating problems becoming expensive....
I had faulty water pump before, it works fine under normal driveing but when you rev it hard the fines would not turn. They just spun on the shaft.
Recommend Just putting one on as its the only thing left to replace.
Also make sure the radiator fan is not catching on anything like the fan cowling.
Mike.
Mike.
- Sandez
15 years 4 months ago #18839
by Sandez
Replied by Sandez on topic Re: Overheating problems becoming expensive....
Section from the service manual
Engine diagnosis table
Overheating
• Inoperative thermostat
• Faulty A/C condenser fan motor or its circuit
• Loose or slip water pump belt
• Poor water pump performance
• Clogged or leaky radiator
• Improper engine oil grade
• Clogged oil filter or oil strainer
• Poor oil pump performance
• Dragging brakes
• Slipping clutch
• Blown cylinder head gasket
Overheating
• Dragging brakes
• Slipping clutch
- ooky_123
15 years 4 months ago #18840
by ooky_123
Replied by ooky_123 on topic Re: Overheating problems becoming expensive....
Thermostat .... again, they donot go that often, but when they do go ... can give similar symptoms.
Its quite easy to do yourself but its a bit fiddly
- mcjimny
15 years 4 months ago #18841
by mcjimny
Replied by mcjimny on topic Re: Overheating problems becoming expensive....
My first thought was thermostat but as it had only been replaced in may and had a load of other work done........
Its an easy diagnosis for anyone, start the car with the heaters off and hold the top hose, if it warms up gradually its stuck open, if it doesn't warm up at all its stuck shut, if it stays cool for a bit and suddenly gets hot its working fine. It should be too hot to hold once up to temperature.
- JoJo
15 years 4 months ago #18851
by JoJo
Replied by JoJo on topic Re: Overheating problems becoming expensive....
For a little engine, the car runs really well. It bothers me that i don't have a surge of power to get me out of trouble, but i've gotta say it never lets me down other than out of the blue o/heating moments. Having said that, it is a serious let-down then, 'cause i cld be on freeway with just me & dog.
Happens when idling at lights, driving on road....totally random, it blew me away when it happened a couple of weeks after the last time when the engine was overhauled & radiator replaced.
I'm not a mechanic & don't understand what is going on. Thnks for manual info too. Will call mechanic tomorrow am, to see how car behaved today.
- JoJo
15 years 4 months ago #18852
by JoJo
Thnks for this, will ask mechanic to give it a go tomorrow & post the result on bigjimny. The support is amazing, thnks all!
