Caster correction bushes. Correct fitting HELP.
- Nobby22
08 Jul 2011 13:58 #18742
by Nobby22
Caster correction bushes. Correct fitting HELP. was created by Nobby22
Hi all
Just wondering what is the correct way on mounting caster correction bushes in terms of getting them at the right angle's. i have seen a diargram but wondered if anyone had any further info. I've got the rubber type one's from jimnybits and they come with no instructions. It looks fairly simple but i assume it has to be precise. Do i need to mark and measure to insure they are fitted correctly? If so does anyone have any instructions?
Thanks for any help.
- dirtydogz
08 Jul 2011 18:17 #18748
by dirtydogz
Replied by dirtydogz on topic Re: Caster correction bushes. Correct fitting HELP.
Hope this helps
www.bigjimny.com/images/documents/fittin...orrection_bushes.pdf
- Nobby22
09 Jul 2011 13:14 #18754
by Nobby22
Replied by Nobby22 on topic Re: Caster correction bushes. Correct fitting HELP.
Thanks dirtydogz for the heads up. Should come in useful.
- dirtydogz
10 Jul 2011 12:07 #18776
by dirtydogz
That ok mate good luck.
Time to create page: 0.193 seconds
