4x4 light flashing
- bashirshah
08 Sep 2011 12:57 #21515
by bashirshah
Replied by bashirshah on topic Re: 4x4 light flashing
first clean the one way valve attached with pipe coming from manifold after that start other procedure
- Fearghal Murphy
09 Sep 2011 19:33 #21574
by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: 4x4 light flashing
Just got my Jimny recently, and had the same problem, checked the vacuum hoses, massive split in the short piece to the manifold, quick repair and all is well !! Best of luck with yours !!
- Fearghal Murphy
10 Sep 2011 01:56 #21580
by Fearghal Murphy
replacement i mean, not repair haha !
12 Jan 2016 16:27 - 12 Jan 2016 16:29 #160220
by Bosanek
Replied by Bosanek on topic 4x4 light flashing
I decided to resurrect this old thread instead of making a new one.
My Jimny was made in 2006, with an electric transfer box.
We had some heavy snow last week, and I was driving for about 150 km on a motorway during the snowfall.
The road was all covered in snow, so I was driving in 4WD-H in 4th or 5th gear at around 50-70 km/h for the entire duration of the trip.
However, I noticed a strange issue soon after I engaged 4WD-H. About a minute after I engaged it, I noticed that the green 4WD-H light began to flash during the driving (it had been normally constantly lit for the first minute of 4WD-H operation).
When I saw that, I disengaged back to 2WD in motion (and immediately noticed that the car is less stable on the snowy road - normal expectation).
After approx 10 seconds, I engaged 4WD-H again. It engaged fine (clicking sound, car got more stable), and 4WD-H light was constantly lit again.
However, after approx 10 minutes of constant driving, the green 4WD-H light began to flash again. It constantly flashed for at least 10 seconds before I disengaged back to 2WD again without stopping.
I then drove in 2WD for at least 30 seconds, and engaged 4WD-H again in motion. After that, the 4WD-H light did not flash during the remainder of the trip, which lasted at least 45 minutes.
I tried 4WD-H and 4WD-L mode a few times during the following days (but only for some short slippery sections which lasted no more than a couple of minutes), and I had no problems.
What could be the issue here?
Last edit: 12 Jan 2016 16:29 by Bosanek.
- Brooklynodog
12 Jan 2016 19:05 #160232
by Brooklynodog
Replied by Brooklynodog on topic 4x4 light flashing
Check out my thread about 4X4 issues here
www.bigjimny.com/forum?view=topic&catid=6&id=59108&start=24
Might seem irrelevant if you read from start so skip to end. It might be the vacuum pipes failing causing the electronics to fail to recognise positive or negative pressure in them, hence causing the 4X4 light to flash. I`m probably wrong, but its worth checking out.
12 Jan 2016 19:22 #160234
by Busta
Replied by Busta on topic 4x4 light flashing
My understanding was the system only checks for vacuum for the first few seconds, as you engage/disengage 4wd. Why it would decide there is a fault minutes after this I have no idea!
Time to create page: 0.110 seconds
