Track rod end problem, help?
- Az1987
06 Jul 2011 20:36 #18663
by Az1987
Track rod end problem, help? was created by Az1987
Hi all I am new to the site, have had a few modded vits before but just got my first jimny
I have a problem with my track rod ends. The front steering arm N/S track rod is worn out and so is the rear N/S track rod but all the parts places I have spoken to have said I can only get the rear one patten part is this right? And are the front and rear track rod ends the same as the look the same to me. If they are not the same anyone no where to get the front one patten part cheers Aaron
- ooky_123
06 Jul 2011 20:40 #18664
by ooky_123
Replied by ooky_123 on topic Re: Track rod end problem, help?
I cannot help with your query, however, Bits 4 Jimnys, Jimnybits & Bigjimny are all the sites you should need. im sure Ive seen trackrod ends somewhere ... someone more knowledgeable will be along in a while who will know for certain
Welcome btw !
Welcome btw !
- dirtydogz
07 Jul 2011 05:40 #18671
by dirtydogz
Replied by dirtydogz on topic Re: Track rod end problem, help?
07 Jul 2011 06:09 #18672
Replied by mlines on topic Re: Track rod end problem, help?
Yep - in my shop -
www.bigjimny.com/store/index.php/jimny-p...-rod-ends/p_128.html
There are two versions depending on which side of the car they are fitted (the thread is reversed on one). Both are available. Not sure why your supplier thinks they are not available.
- darthloachie
07 Jul 2011 10:39 #18685
by darthloachie
Replied by darthloachie on topic Re: Track rod end problem, help?
No eBay APP ID and/or Cert ID defined in Kunena configurationalso try ebay
Time to create page: 0.171 seconds
