Radio
- Ian
15 Jan 2010 12:43 #1857
by Ian
Radio was created by Ian
Hi, does anyone know if the 06 Jimny with built in radio needs a code if the batteries disconnected? Cheers Ian.
- Jamie
15 Jan 2010 15:49 #1858
by Jamie
Replied by Jamie on topic Re:Radio
Only if the previous owner or yourself have given it one!!
From factory they dont have a preset code
but in the manual for the radio there is an option to give
it a code if you get what i mean!!
- Ian
15 Jan 2010 16:54 #1860
by Ian
Replied by Ian on topic Re:Radio
Thanks for that, just in case I have decided to put a direct feed to the radio fuse from the positive terminal and disconnect the battery from the rest of the car. Hopefully this will reset all the electronics and I can get my car out of 4WD or not! Cheers Ian.
- Jamie
15 Jan 2010 17:15 #1861
by Jamie
Where about's are you Ian???
- Ian
15 Jan 2010 17:31 #1864
by Ian
Fareham between Portsmouth and Southampton.
- Jamie
15 Jan 2010 18:30 #1868
by Jamie
Ahh bit too far for me, I'm in Leeds!
I can't think of any other reason your hub's won't unlock!!
Have you checked all the plug connectors on the transfer box
are all plugged on and clean????
Other than that i'm out of idea's!!
Jamie
Jamie
