front damper extension brackets
- dadam
01 Jul 2011 20:48 #18478
by dadam
What shape did you use? (the same square shape as on ebay or like the one you can see on the link i've posted above or something else...)
Replied by dadam on topic Re: front damper extension brackets
Sorry, a false friend from french to english...:blush:mlines wrote: Not sure what you mean by process, mine fit all types of shock.
- Fingers
03 Jul 2011 13:18 - 03 Jul 2011 13:19 #18513
by Fingers
Replied by Fingers on topic Re: front damper extension brackets
I've got the 2" front shock extension boxes fitted to mine, the ones posted at the top [ebay ones]..
there fine, I've got them fitted with 2" spring spacers too and extended brake lines. all works well.
If you want to see some pictures , look at the ( my jimny ) section . thread called "Jon's jimny"
Jon
Jon
Last edit: 03 Jul 2011 13:19 by Fingers.
- Fingers
03 Jul 2011 13:23 #18514
by Fingers
oh , another thing to consider is,
You need to make the bolt captive.
I mig welded the bolt head to the box section in 2 spots on the inside!
- panosd
05 Jul 2011 12:15 #18603
by panosd
Replied by panosd on topic Re: front damper extension brackets
www.bits4vits.co.uk/store/vitara-/-x90/s...ers-2-/prod_203.html
these brackets i was thinking about. After talking with B4vts he told me that these fit only at oem and
old man emu shocks. The other patern '' [ ] '' is being used at my brothers vitara for almost 3 years now
at daily use and 2 off-road competitions and are great, still on position.
Martin do you have any image of the set you are making?
