front damper extension brackets
  • myers647
30 Jun 2011 18:11 - 01 Jul 2011 04:57 #18422 by myers647
front damper extension brackets was created by myers647
No eBay APP ID and/or Cert ID defined in Kunena configurationHi,
, has anyone ever used these front damper extension brackets before, are they worth having if so im going to buy these Item number: on ebay.
thanks
Last edit: 01 Jul 2011 04:57 by mlines.
30 Jun 2011 21:32 #18428 by kirkynut
I think the Vitara boys and girls have used them with good effect for some time.
Dave will tell you...... Dave?
  • dadam
01 Jul 2011 00:06 #18429 by dadam
Replied by dadam on topic Re: front damper extension brackets
I'm thinking of using it if i keep my actual lift, but i will most think of something like that:
www.bits4vits.co.uk/store/vitara-/-x90/s...ers-2-/prod_203.html
The problem is they can't adapt on all shocks like the one you found on ebay, but i think it's stronger and safer.
The vitara mostly use that type of brackets ;)
01 Jul 2011 04:56 #18431 by mlines
My version is in prototype, does anyone near me in Berkshire want to try a set?
  • dadam
01 Jul 2011 09:11 #18438 by dadam
what kind of process did you chose?
Will it only fit OEM ones or aftermarket ones too Martin?
01 Jul 2011 11:22 #18445 by mlines
Not sure what you mean by process, mine fit all types of shock.
Time to create page: 0.301 seconds
