clutch slip
- jason92
25 Jun 2011 21:00 #18264
by jason92
my clutch slipes if going slow in second gear and putting my foot down is there any adjustment?? or do i need a new clutch if so how easy are thay to fit? thanks jason
clutch slip was created by jason92
26 Jun 2011 07:09 #18275
by facade
Replied by facade on topic Re: clutch slip
There is adjustment under the car where the cable goes into the gearbox.
There should be about 1/2" of free play in the pedal.
If there is free play, you need to look at the clutch, maybe the clutch is worn, or the release arm is sticking.
The following user(s) said Thank You: jason92
- manualejo
28 Jun 2011 14:09 #18357
by manualejo
Replied by manualejo on topic Re: clutch slip
Or the cable is stretched, as in my case it was a little bit of everything and the broken cable support
- jason92
13 Jul 2011 23:28 #18928
by jason92
Replied by jason92 on topic Re: clutch slip
my rocker cover is leaking a bit down on top of my gearbox can the oil get in and make the clutch slip?? thanks jason
14 Jul 2011 16:31 #18959
by facade
Doubt it, the gearbox is tight against the block, and drains at the bottom, oil would have quite a route to travel to get to the friction plate.
