4wd light
  • bazwidajimny
21 Sep 2008 20:40 #178 by bazwidajimny
4wd light was created by bazwidajimny
hi guys been out off-roading today, been through some deep bogs. when i came out put it back in 2wd, 4wd light went out but didnt hear the free-wheeling hubs click out. when i put it back into 4wd-the light didnt come on but still had 4wd. then the light started to flash??..?? i think the hubs are not diss-engaging, any ideas on what it is and how to fix??..??
thanks guys
bazz
21 Sep 2008 20:51 #179 by mlines
Replied by mlines on topic Re:4wd light
Usual one is you have split or ripped the vacuum pipes. If they were really deep you may have filled the solenoids with crap, these are located under the fuses by the battery. Or you may have mud in the hubs which will mean a strip and clean.
Check the pipes first
  • bazwidajimny
22 Sep 2008 18:17 #182 by bazwidajimny
Replied by bazwidajimny on topic Re:4wd light
thanks ill have a better look 2 mozz is thear a way ov locking them permenantly or is thear a manual free wheel hub that will fit like sj or is thear new 1s out thear 2 buy
22 Sep 2008 19:18 #185 by mlines
SJ manual hubs fit but you need to get a space ring made up. I have not seen it but a number of people have done it, apparently the spacer needs to be around 5-6mm.
  • bazwidajimny
22 Sep 2008 19:59 - 23 Sep 2008 17:08 #186 by bazwidajimny
iv heard u can weld up the hub so they're in all the time. any idea how this done m8? pics would b great. sj hubs do they need 2 be off a 413 or will 410 1s fit as well whot about manual free wheeling hub of an sj will thay fit and whot about vitara 1s got 2 try and get it fixt for the weekend. thanks
bazz
Last edit: 23 Sep 2008 17:08 by bazwidajimny.
Time to create page: 0.147 seconds
