Cam sensor issues??
  • DVs-Jimny
14 Jun 2011 13:14 #17775 by DVs-Jimny
Cam sensor issues?? was created by DVs-Jimny
At sustained speeds of 55 - 60MPH I seem to get a little hiccup now and again. It's as if I've gone and lifted off the throttle hard and then put my foot back down.
1999 Jimny SOHC
I'm thinking cam sensor going wobbly (no CEL on), no other apparent symptoms.
What do you guys think?
Thank you :)
  • DVs-Jimny
14 Jun 2011 18:14 #17792 by DVs-Jimny
Replied by DVs-Jimny on topic Re: Cam sensor issues??
Anyone??
  • NickG
14 Jun 2011 18:20 #17793 by NickG
Replied by NickG on topic Re: Cam sensor issues??
Is it a pig to start some times
take a good look at the wires ?????? maybe corrosion
in the trminals .:unsure: :unsure:
will think on.;)
  • lex1471
15 Jun 2011 17:08 #17847 by lex1471
Replied by lex1471 on topic Re: Cam sensor issues??
I have the same symptoms on my 02 jimny. If I run at light load say up to 50mph it will run all day. If I make it work harder 60mph after a couple of miles it will cut out but may not stop running. The tacho needle flicks to zero and the engine warning light flickers. Leave it a couple of minutes and we are off again as if nothing was wrong.
I changed the front O2 sensor without success and also got hold of a second hand cam sensor which also made no difference.
May have to try a new cam sensor though.
Somehow this seems to be temperature related but would appreciate some views on this.
So DVs Jimny seem like the same issue to me. Sorry I cant help.
  • zaine
16 Jun 2011 08:47 #17868 by zaine
Replied by zaine on topic Re: Cam sensor issues??
i had exactly the same problem with my 2002 jimny, i changed the cam and the crank sensor, all fixed :)
Time to create page: 0.144 seconds
