Broken it... crankshaft pulley
- SPC5838
07 Jun 2011 18:40 - 08 Jun 2011 20:22 #17488
by SPC5838
Broken it... crankshaft pulley was created by SPC5838
On the motorway this morning, the Jimny decided to break for the first time in 2 years, something along the lines of BANG :woohoo: what the **** was that :huh: battery warning light on, no power steering and getting hot very quickly... Turns out the crankshaft pulley had decided to split in two and pulled both the belts off
The new one, all £140 quid of it :S Looks the same as the one that came off, so presumably it's 2 bits joined together as well.
Just in case anyone needs the part number... great fun changing this in a car park. Bolt holding it on was rock solid, only way to loosen it with tools available ( don't try this at home ) was jam a 1/2" drive 18" bar under the left hand chassis rail with a 17mm socket on the bolt and turn the key... que second bang of the day and one loose crankshaft bolt :laugh: Worked, but not recommended ! Another Jimny owner decided to come have a chat about them when he saw me working on it... what other modern car does that happen with
Apologies if this has been posted before, but has anyone else had the pulley fail like this ? It's got 35k on the clock and if the new one is made the same way as the one that split, it seems there's a chance it could happen again :S
Attachment 001.jpg not found
Attachment 002.jpg not found
Attachment 004_2011-06-07.jpg not found
Last edit: 08 Jun 2011 20:22 by SPC5838.
- renard38
08 Jun 2011 13:48 #17515
by renard38
Replied by renard38 on topic Re: Broken it... crankshaft pulley
where this pice come's from??? have you got a picture on the jimny?
thanks
thanks
- VAXXi
08 Jun 2011 14:22 - 08 Jun 2011 14:23 #17518
by VAXXi
Replied by VAXXi on topic Re: Broken it... crankshaft pulley
It's the one mentioned in the service recall:
Recall Details
Concern: LOSS OF STEERING ASSISTANCE.
Description: Steering assistance may be lost because the the power steering tensioner pulley material is not to specification. The pulley may fail and cause a loss of drive to the hydraulic pump.
Remedial Action: Recall the vehicles that are likely to be affect to inspect and where necessary replace the power steering tensioner pulley.
Vehicle Id: JSAJTA74V00100056 to JSAJTA74V00200237, JSAFJB43V00300011 to JSAFJB43V00213672, JSAJTD94V00101295 to JSAJTD94V00101296, JSAHTX92V00209650 to JSAHTX92V00209812.
Numbers Involved: 5424
Recall article is here .
Part codes:
49160-64J01, PULLEY, BELT TENSION
17521-84H00, BELT (4PK850)
49111-81A40, .PULLEY (seems to be different than the one posted above by SPC5838 though).
Recall Details
Part codes:
Last edit: 08 Jun 2011 14:23 by VAXXi.
- renard38
08 Jun 2011 16:12 #17522
by renard38
strange, mine is not like this...
- SPC5838
08 Jun 2011 20:21 #17540
by SPC5838
Replied by SPC5838 on topic Re: Broken it... crankshaft pulley
Sorry folks, looks like I was given duff info about what the issue was with the recall :blush: VAXXi's correct, the recall was for the PAS pulley, not the crankshaft pulley as I was told
The garage that it went to to for the recall isn't a Suzuki franchise anymore ( they're no longer trading
) so guessing that minor detail didn't matter much to them ! Post amended to save confusion... Also explains the difference in part number :blush:
Anyway, it wasn't the PAS pulley that broke up. It was the main crank pulley for the alternator, PAS belt and fan. I don't have a picture Renard but the arrow points to it, part 2 in VAXXi's diagram.
According to the dealer I got the new one from they've sold "quite a few" and although they don't think it's a weakness in the same way as the kingpins, it was obvious this wasn't the first one they'd seen that the pulley had broken up on. Worrying thing is there was nothing leading up to it failing -no rattle, belt noise, battery light flickering, nothing. Just bang and that was it. The bonding between the 2 parts ( looks like thick 3M tape, the 2 bits aren't even resistance fit ) failed totally and left one half attached to the crankshaft, the other half wedged in the back of the fan and the belts tied in knots
Attachment screenshot20100816at318.jpg not found
- VAXXi
09 Jun 2011 07:02 #17552
by VAXXi
Very unfortunate
quite a shame to have it so poorly engineered, and 1/2 bolts between the two plates seems to be out of the question, as it would be probably very hard to balance it properly.
Time to create page: 0.107 seconds
