jimny newbie ...help!!
- jonnyebz
21 Sep 2008 08:46 #174
by jonnyebz
jimny newbie ...help!! was created by jonnyebz
Morning all, ..just bought first jimny !! the engine had seized , so thought would swap engine, hey presto , but thought would at least look at dmage to current engine , trouble is
there's a symbol on the dash "jimny with padlock" which I presume is an immobiliser of sorts , but can't find way around it to test engine ...is it an immobiliser, is it something else .any help would be appreciated
Cheers...Jon
Cheers...Jon
21 Sep 2008 09:05 #175
Replied by mlines on topic Re:jimny newbie ...help!!
Yes it is the immobiliser.
A simple engine check will be to remove the spark plugs (under the cover on top of the engine if its an M13AA engine and turn it over with a large spanner on the font pulley.
It could be that the ECU/immobiliser is the real fault and the engine is ok.
I assume you have the real set of keys for it as these should de-activate the immobiliser. Otherwise you will have to start looking at it with a Multimeter and follow through the checks in the workshop manual.
Where abouts in the country are you, I have a code reader that can read the simple codes from the ECU (but not the Suzuki specific codes)
Reading, Berks
Reading, Berks
21 Sep 2008 09:06 #176
And with a few bits of wire you should be able to persuade the starter to turn the engine.
- jonnyebz
21 Sep 2008 09:12 #177
by jonnyebz
Replied by jonnyebz on topic Re:jimny newbie ...help!!
Thanks for that Martin , I will try the things you've suggested, Unfortunately I'm in west wales near carmarthen, but as you say I'll run through the basics first and see where we get ,
Cheers.Jon
Cheers.Jon
Time to create page: 0.189 seconds
