Engine light on
- Johnniehec
- Thank you received: 56
31 May 2011 15:33 #17147
by Johnniehec
OUCH!!:ohmy:
Replied by Johnniehec on topic Re: Engine light on
expense wrote: nothing worse than your engine light coming on! my car is a 52 as well, with only with only 25,000 on the clock, first rear sensor, then the second only 2 miles up the road! someone else on here said when one goes the other one is quick to follow !! one cost £93 and other was £132, with the test.
OUCH!!:ohmy:
- deerwarden
01 Jun 2011 20:54 #17207
by deerwarden
Replied by deerwarden on topic Re: Engine light on
Hi all, looks like the Front lambda has gone, Suzuki quoted me £134 pounds just for the sensor, do the direct replacement from Denso work O.K. if so whats the best one for my 51 plate Jimny, we had the local garage fit a universal into the Vitaro and had to replace it as it wasn't running right, all input appreciated. deerwarden:)
- doncarlyon
02 Jun 2011 06:54 #17219
by doncarlyon
Replied by doncarlyon on topic Re: Engine light on
- deerwarden
02 Jun 2011 17:06 #17234
by deerwarden
Tried my new code reader and it found the following, PO135 02 sensor heater circuit bank 1 sensor 1, is this the front 02 sensor on the manifold, can't read codes till I go into work tomorrow as my computer doesn't have a mini disk reader. deerwarden
- doncarlyon
02 Jun 2011 17:26 #17238
by doncarlyon
Yes that will be the front sensor.
CarpartsExpress can get the Bosch sensors for around £80 i believe.
