Steering damper bracket
- leswilluk
26 Dec 2009 16:12 #1697
by leswilluk
Steering damper bracket was created by leswilluk
Hi I have just had a go at fitting the steering damper brackets from the BigJimny shop but there is something I am not sure about my Jimny still has the anti roll bars fitted which means that the bracket attached to the cross member is very close to the bar about an inch away I am concerned that if the suspension is compressed that the bracket may hit the bar, to late to do any more today will have another look tomorrow but I will not drive it like that and will remove it until I am sure it will be OK thanks
26 Dec 2009 16:32 #1698
Replied by mlines on topic Re:Steering damper bracket
Hi
Thats not good news, sods law says that all the vehicles it has been fitted to so far have been off-road vehicles with the anti-roll bar removed so I did even consider the anti-roll bar when designing it.
There is an element of "rotation" available on the brackets at both end of the damper, by rotating it can you gain more room? Also the cross member bracket does have two holes in it so that the damper can be mounted higher up on vehicles without large suspension lifts, this would also allow the long end of the bracket to be cut short in these instances, would this help you?
I would appreciate some photos of the problem and if it cannot be overcome then I will arrange to take it back and give a full refund.
- leswilluk
27 Dec 2009 12:51 #1706
by leswilluk
Replied by leswilluk on topic Re:Steering damper bracket update
Hi I have tried moving the bracket into different positions on the cross member but still to close for comfort I think it will be OK if I used the top mounting hole and cut the bottom of the bracket off but the damper will not fit alongside the pipework which runs over the bracket as you may notice from the pictures my Jimny is a bit to new to modify to much.
- leswilluk
27 Dec 2009 12:54 #1707
by leswilluk
Replied by leswilluk on topic Re:Steering damper bracket update a another pic
27 Dec 2009 19:29 #1709
Replied by mlines on topic Re:Steering damper bracket update a another pic
Les,
I can see the issue, I think there are two ways forward on this:
1. I refund your money/postage etc and you pop the brackets back to me.
2. It looks as if I make a variant of the bracket which has a hole just below the current top hole and is then cut short below the new hole that this might work? Do you think so as you can see better the whole issue, yours is the first Jimny I have seen with the anti roll bar still fitted!. It would take about 3 weeks to get one done (the engineer is away snowboarding!). Would you be prepared to wait??, I need to sort out a solution for vehicles with Anti-roll bars still fitted.
Let me know either way,
- Jamie
27 Dec 2009 19:56 #1710
by Jamie
Replied by Jamie on topic Re:Steering damper bracket update a another pic
Get the ARB off if you are off roading it's just a hinderance!!!
Time to create page: 0.278 seconds
