Prop spacers?
- Nobby22
19 May 2011 17:06 #16567
by Nobby22
Prop spacers? was created by Nobby22
Hi all
First of iam a newbie to this site. Planning to give my jimny a 3" suspension lift so i thought i should join to ask and get advice.
I pretty much know everything i need but i carnt work out if i need, if so what size 1/2" or 1", a prop spacer. Any advice will be greatly recieved.
Oh, i will post a "hello" on the "My Jimny" section.
Thanks.
Thanks.
- supergaz
19 May 2011 18:13 #16571
by supergaz
Replied by supergaz on topic Re: Prop spacers?
Welcome to Big Jimny.
A prop spacer is only needed if castor correction arms are used. I have a 4.5'' lift and 4.5'' correction arms, I needed a prop spacer due to the extra droop on the front prop, the prop was failing on the gearbox cross member.
- Nobby22
20 May 2011 12:05 #16596
by Nobby22
Replied by Nobby22 on topic Re: Prop spacers?
Thanks for the relply. I will be putting caster correction bushes in. So do you think i will need a spacer? Or is it only if i completely change the arms to corrected ones?
Thanks again
Thanks again
- supergaz
20 May 2011 19:57 #16621
by supergaz
You wont need a prop spacer. Its only with a'lot of caster correction as the axle is a'lot lower than the transfer box, this gives it a'lot of droop on the prop and so it fouls on the chassis cross member.
- Nobby22
21 May 2011 09:46 #16646
by Nobby22
Thats great thanks. Will put some pics up when i start the lift.
