Propshaft Bolts
  • ooky_123
09 May 2011 08:52 #16082 by ooky_123
Propshaft Bolts was created by ooky_123
Does anyone know offhand the size of bolt that is needed to mount an SJ shaft to a Jimny diff ?
I know they are M10 but I was wondering what length to get as I sont fancy getting 100mm ones and having to cut and recut the damaged threads on 20 bolts ?
Im guessing I should beable to get away with either 40mm screws of bolts but wanted to make sure before I go ordering 20 of the items
  • vitara_mad
09 May 2011 13:06 #16087 by vitara_mad
Replied by vitara_mad on topic Re: Propshaft Bolts
if its to fit a sj prop with large flange to the rear diff then you just use the bolts you took out when you remove the jimny prop as they thread into the diff flange
  • ooky_123
09 May 2011 13:27 #16088 by ooky_123
Replied by ooky_123 on topic Re: Propshaft Bolts
Cool. Cheers ... just making sure I get everything ready for the TX bos swap.
Time to create page: 0.137 seconds
