Re: teething problems
  • Fingers
15 years 6 months ago #16020 by Fingers
teething problems was created by Fingers
ok. i've took ownership of my new jimny. well [2002] jimny actual.
and it got a few little thing i'm not super happy with.
1. gear selection can be difficult. mainly 1st and reverse. I've checked there's plenty of oil in the main gearbox. any ideas what else it could be??
2. clutch noise when idling. if you leave it in neutral. engine running you hear a ticking noise, but if you apply just 1/2 an inch of clutch peddle travel it goes away.
dry thrust bearing of something???
3. high biting point on the clutch, sign of heavy clutch wear???
any advice would be appreciated. Cheers Jon
  • vitara_mad
15 years 6 months ago #16022 by vitara_mad
Replied by vitara_mad on topic Re: teething problems
have you tryed adjusting the clutch cable ????
15 years 6 months ago #16023 by facade
Replied by facade on topic Re: teething problems
1) Normal: first is difficult when the gearbox is cold. Try changing the gear oil to the sx75/90 synthetic.
(No idea about reverse, I rarely go backwards except to go back into the drive, obviously it is warmed up when I get home.)
2) could be. Mine whirrs like a good 'un and goes quiet when I press the clutch.
3) There is an adjuster at the gearbox end of the clutch cable.
I guarantee it is seized solid.
Pull the plastic cover off the bell housing where the clutch arm is, unhook the cable from the arm, and pull it out. You can get it out of the front of the car over the radiator and free the adjuster wheel.
Adjust it to give some free play at the pedal. (1/2 to 3/4 of an inch)
If that doesn't fix it, think about a new clutch
  • Lemsip81
7 years 5 months ago #209138 by Lemsip81
Replied by Lemsip81 on topic Re: teething problems
Any advice on un-seizing the adjuster nut on the clutch cable? I’ve removed from the gearbox end and have tried the usual wd40 soaking but will not budge even with a pair of water pump pliers
7 years 5 months ago #209140 by Lambert
Replied by Lambert on topic Re: teething problems
Persistent gentle persuasion. Be careful.
  • Cremator1
7 years 5 months ago #209141 by Cremator1
Replied by Cremator1 on topic Re: teething problems
Plus gas far better than wd40
