steering damper vs shock absorber
- THOR
15 years 6 months ago #15679
by THOR
steering damper vs shock absorber was created by THOR
hi guys...i'm just curious...is there a difference between a steering damper and a front shock absorber?
can i use a shock absorber instead of a steering damper?
they look really similar....just thinking...
- darthloachie
15 years 6 months ago #15685
by darthloachie
Replied by darthloachie on topic Re: steering damper vs shock absorber
yep - same thing - you'll need a fitting kit as well - see the big jimny shop
- Asbojimny
15 years 6 months ago #15688
by Asbojimny
Replied by Asbojimny on topic Re: steering damper vs shock absorber
Not that i know a lot
And i may be wrong.
But i thought a steering damper works both directions and a suspension shocker dampens only in the compression ( upwards) movement.
You can get a Disco steerin damper for about 20 squids.
15 years 6 months ago - 15 years 6 months ago #15692
by Obarno
Replied by Obarno on topic Re: steering damper vs shock absorber
I would buy a proper steering damper, most shocks have different rates of resistance for compression and extension and also some/most don't work well when mounted on their side.
Last edit: 15 years 6 months ago by Obarno.
- lukeyblunt
15 years 6 months ago #15694
by lukeyblunt
Replied by lukeyblunt on topic Re: steering damper vs shock absorber
Hi all !!
I'm considering getting a steering damper (or similar) too.
What are the pros against the cons?
Do they make it physically harder to steer?
Will it stop my Jimny bouncing over the road? :blink:
Many many thanks !
Luke B
Many many thanks !
Luke B
- vitara_mad
15 years 6 months ago #15699
by vitara_mad
Replied by vitara_mad on topic Re: steering damper vs shock absorber
tbh i fitted one to mine & one to my bro's & i don't think theres any noticable differance with it fitted or not
Time to create page: 0.096 seconds
