Recovery Points
  • doncarlyon
15 years 6 months ago #15656 by doncarlyon
Recovery Points was created by doncarlyon
Is anything "bolt-on" available for the front of a Jimny?
Also can anyone recommend any tow ropes, etc? Wont be doing anything extreme, just be handy to have something in the car.
  • dirtydogz
15 years 6 months ago - 15 years 6 months ago #15667 by dirtydogz
Replied by dirtydogz on topic Re: Recovery Points
You could always make one like Richie
www.suzuki4u.co.uk/forum/viewtopic.php?t=9975
This the only bolt-on lve found.
en.item.rakuten.com/apio/3070_16/
Last edit: 15 years 6 months ago by dirtydogz.
  • mcjimny
15 years 6 months ago #15669 by mcjimny
Replied by mcjimny on topic Re: Recovery Points
The apio bolt on ones are the only ones i've seen too. I'm going to get some made up hopefully that are similiar.
If you search on difflock for "lifechooser" theres a thread on there about the apio ones, he got some via a friend of his that imports jap motors iirc.
The standard ones are ok for a "gentle" pull and definitely no snatch recovery. I use a short strap across the 2 and a 4 metre strap. I've not been stuck for a long time though and only needed any help when i was cross axled(will get it stuck again in the same spot to try left foot braking and see if i can get out). I'd always recommend a bridle to halve the load seen at each point. The points on mine have a small hole at the bottom and a bigger one nearer the chassis i use these as i cant get the shackles through the others, be aware that it will pull against the bumper - especially if you're not pulling perfectly straight.
My straps are from damar(sp) webbing on ebay, i got the short one from them at a show though. Another was acquired from a mate. I'd not use a KERR on the stock points.
Straps are easier to handle and to clean imo. You'll need some shackles too, i use blue pin ones again i think the cheapest i could find them was ebay. I tried local lifting suppliers and everything was a fortune.
Bertie bas on difflock is highly recommended on there for recovery gear.
  • VAXXi
15 years 6 months ago #15764 by VAXXi
Replied by VAXXi on topic Re: Recovery Points
The lacking recovery points also worry me, as the tie-down eyelets aren't really that strong. Proof:
[IMG
[IMG
Japanese APIO makes some very interesting attachments, but I haven't researched the topic of shipping yet. It looks to be quite expensive anyway, for just a few pieces of metal. Hope these pics give someone the idea of manufacturing them closer to Europe :whistle:
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
  • doncarlyon
15 years 6 months ago #15855 by doncarlyon
Replied by doncarlyon on topic Re: Recovery Points
Was winched out of a muddy swamp at the weekend using the standard rear one and it seemed ok. My mate also winched himself (Fourtrak) out of a bog using the front standard ones on my Jimny. So they are ok for that.
15 years 6 months ago #15856 by Johnniehec
Replied by Johnniehec on topic Re: Recovery Points
VAXXi wrote: The lacking recovery points also worry me, as the tie-down eyelets aren't really that strong. Proof:
[IMG
VAXXi How on earth did you manage that!!? I'm guessing kinetic recovery.
I have a standard towbar on the back and that's been used on the few occasions I've been recovered backwards, by winch, I wouldn't use it for kinetic though.
doncarlyon, I've used a strop between the standard front eyes, again for winch recovery, wouldn't do kinetic on their either.
I remember an incident many years ago recovering a Trooper with the official Izuzu tow rope, the forged hook on the end of it made a beautiful hole through the rear door of the Ninety as it straightened and let go of the Trooper when the "load" was applied. Recovery is a dangerous excercise.
Cheers,
John.
Time to create page: 0.124 seconds
