changed engine now it wont run
- vitara_mad
25 Apr 2011 12:52 #15473
by vitara_mad
changed engine now it wont run was created by vitara_mad
we have fitted a replacement engine in my bro's jimny today but it won't start even though everything has been connected up the way it should be
when we first turned ignition on the lights on the dash came on for a split second then went off found it blew a fuse so replaced that so now got ignition lights & engine turns but not atempting to fire up
anyone got any idea's what it could be
its a sohc engine & we just taken it out of another jimny that was running perfectly fine
- doncarlyon
25 Apr 2011 15:03 #15483
by doncarlyon
Replied by doncarlyon on topic Re: changed engine now it wont run
Immobiliser?
- vitara_mad
25 Apr 2011 15:07 #15484
by vitara_mad
Replied by vitara_mad on topic Re: changed engine now it wont run
i thought about imobiliser as the old engine was removed about 2 months ago & its been sat there with the battery disconected all that time so maybe its lost its code but i thought that the check engine light flashed when the ignition is switched on if its the imobiliser but i could be wrong
- vitara_mad
27 Apr 2011 15:17 #15561
by vitara_mad
its not the imobiliser i changed the ecu , imob unit & ignition today & it still the same
- Thank you received: 115
27 Apr 2011 15:21 - 27 Apr 2011 15:21 #15562
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: changed engine now it wont run
i had the same with mine ... turned out to be dud/duff/rusty Coil packs.
Jalapeño, IISY?
Last edit: 27 Apr 2011 15:21 by maverick.
- vitara_mad
27 Apr 2011 18:45 #15570
by vitara_mad
will give them a try but they are the ones that was on the engine & it was running fine in the jimny we just took it out of
maverick wrote: i had the same with mine ... turned out to be dud/duff/rusty Coil packs.
Time to create page: 0.164 seconds
